alarm starts intermittantly
coventryslk
Coventry
W204 CDI Sport
my alarm goes off on its own accord. Been going off more lately and its starting to irritate! Lockin doors with the key now. Any ideas whats setting it off?
bigasotonuk
Southampton UK
C43/55 AMG 1999 / C230K 1997
Are your interior lights working correctly? inc. the boot, you could try checking the door and boot pin switches. Try turning the interior sensors off when you get out of the car as it has been known for tiny spiders and the like to get under the covers of the movement sensors (this is the case on w202s) and set the alarm off. Failling all this my next move would be to replace the alarm siren as when the car gets older the back-up battery in the siren fails, this is a very cmmon fault when i bought my new one it was about £55-60.
Problem in the boot PSE area I think,,and we have had our fair share of rain
coventryslk
coventryslk
Coventry
W204 CDI Sport
pse? What is that and where in the boot is it?
coventryslk
coventryslk
Coventry
W204 CDI Sport
the alarm sounds, and the lights flash too. Alarm goes off after a bit and lights continue to flash
Have a look in the boot to see if there is any water anywhere, and take a good look around the roof/ locking pump, see if you can see any water marks or damp
Alex Crow
Super Suffolk
the pse is in the o/s boot area low down (beneath the plastic trim) encased in foam. always worth checking for any sign of moisture in this area and check plugs etc for any corrosion.
definitely try locking with the interior motion and tow away sensors turned off (by pressing switch on dash) to see if this helps. personally i would read the fault codes first, but hey....................
coventryslk
coventryslk
Coventry
W204 CDI Sport
no lights come on dash and i dont have an OBD diagnostic unit
coventryslk
coventryslk
Coventry
W204 CDI Sport
no lights as in engine management fault lights etc
This fault will not put any lights on,,did you find any damp in the boot
coventryslk
coventryslk
Coventry
W204 CDI Sport
coventryslk
coventryslk
Coventry
W204 CDI Sport
no damp found. Dry and like new in the boot
bigasotonuk
Southampton UK
You will have a diagnostic socket, on a 202 c class it is under the bonnet, in front of the passenger side of the windscreen. Not 100% sure on a SLK the exact position but most MB's are in this position but some i have been told are in the cabin somewhere.
antijam
Gloucestershire
2003 SLK320
On the SLK the diagnostic socket is under the dash immediately behind the bonnet release lever. It is covered by a snap down lid.
To be of any use to you, you will of course need an OBD reader such as this for example.
Alex Crow
Super Suffolk
that obd reader will not do pse codes, i believe they only deal with engine management codes.
did you actually remove the pse unit in the place i described? this needs to be inspected carefully for damp and corrosion at plugs - the boot area itself may not show any signs of damp but the pse modules are very prone, on the 170, to water ingress.. also try locking without sensors, also as described.
bigasotonuk
Southampton UK
If it is plugged into the MB diagnostic tool it gives you the ability to interogate the alarm system itself and it will tell you why the alarm system was triggered, i don,t believe you will get the this functionality with any other code reader.
coventryslk
coventryslk
Coventry
W204 CDI Sport
  • #18
can you clear fault codes with this? Ive noticed that if you lock the car with the remote by pressing it twice, the alarm is likely to sound, not right away though
I still think that the rear SAM / PSE has a fault or the horn is short circuit,,disconnecting the horn first is the easiest thing to do
jp
Wimbledon
2007 E280 sport estate. Aprilia RSV1000 Tuono, CCM 404, Mk1 le mans
Spider
My alarm went off a couple of times the other night for no apparent reason.
A couple of days later I found a small spider which I caught and evicted and the alarm hasn't gone off since!
A nice non technical answer for you...
www.W140.co.uk&www.r129.co
