Alternator Pulley
Pingy
I have E220 CDI, W210 2002 which has destroyed the alternator bearings and the pulley, replacing the bearings should be very easy but I can’t work out if the thread on the pulley is right-hand or left-hand! I’d be very grateful is someone could advise me.
The Alternator is a Dephi P/N 000 150 1650.
P
Pingy
Hi Graeme,
Yes, mine has the overrun clutch, I'm not sure which caused the problem but both bearings and clutch are destroyed. I have the correct key for the inner bolt of the pulley and as I can grip the pulley I was hoping to remove it and then get the local dealer to tighten on the new pulley. That should save me buying the special tool which I would (hopefully) use once! Your document was very interesting thanks but it doesn't mention the thread rotation! Thanks again.
M80
Derbyshire
I would assume that the rotation of the alternator would cause tightening as apposed to loosening ????
P
Pingy
Hi Martin,
Yeah, I bet you're right but I removed the alternator before making note of the direction, I was hoping to avoid starting her up without the belt and no water!
M80
Derbyshire
A short spin wouldn't cause harm.
I've just checked mine (C220 CDI 2004 facelift), the alternator spins clockwise looking from front, I'd be surprised if yours were different.
P
Pingy
Just given it a try and it is the same direction as your, I guess that means it's a left-hand thread then?
Thanks again
dieselman
A diesel
Thanks again
No, it means it's a right hand thread. A left hand thread would tend to loosen when driven clockwise.
Rappey69
hants
c220 w204 amg sport
I bought the tool for removal form eurocarparts, was something like £34 which came with adapters for all makes of car.
there is no way it could be changed without it !
P
Pingy
The pulley its self isn't threaded, it's the bolt through the middle so wouldn't that make you think it's a left-hand?? I've tried turning both way but with excessive force.
P
Pingy
Hi Rappey69,
Because the pulley has collapsed I can grip the inner race to undo it but can you remember which direction it is to undo?
M80
Derbyshire
I hope you get your answers, it sounds like you've had a frustrating afternoon.
Been there many times, good luck.
P
Pingy
Thanks Martin,
A little fustrating yes but I still have transport should all else fail, a 1986 ambulance!
Rappey69
hants
c220 w204 amg sport
Am pretty sure when pulley is held bolt is undone anticlockwise .
It was tight as hell and required a lot of force to undo .
Rappey69
hants
c220 w204 amg sport
you will need the tool to put the new pulley on (if you dont already have it) and can be bought for as little as £17.
Read lots of old posts about pulley removal and no one mentioned anything about it being lh thread so that also points to undoing it the normal way.
P
Pingy
Thanks Rappey,
I'll give it a go tomorrow and see what happens, my blow torch my come in handy!!
muller1
I live near Turriff in Aberdeenshire.
ML 270 Cdi and S type Jag 2.7 Diesel Sport Saloon, and now a VW diesel GT golf
Left or right
Having just had one dene about 1500 miles ago the tool is a torx male and hollow female.
The hollow one holdsthe clutch pulley and the male one fits the bolt.
The bolt is standard rotation, ie right hand thread.
Right to tighten and left to undo.
The bolt needs to be "fairly" tight not rock bar tight as the rotation tends to keep everything snugged up.
Mike
P
Pingy
Thanks to everyone for your help.
What was confusing and just to confirm for anyone else taking on this task: what appears to be a torque bolt in the middle of the pulley is actually the end of the alternator shaft, so hold the shaft and turn the pulley in the normal direction to remove. It's so obvious once you've removed it!
Rappey69
hants
c220 w204 amg sport
Here you go, £20 from ebay !
Splined item in lower rhs of box sits in splines of pulley, torx with socket on end goes through centre, hold one, undo other.
BlackC55
South coast
C43
For £20 it will be crap as they can be very very tight and I have broken two recently (good quality sets)
