ambient lighting not working
curlyman
e class 220d 4matic estate
hi my ambient lighting not working on 2018 220d estate w212 brightness checked all ok where is fuse for this does anyone know TIA very much appreciated :)
or any other ideas ?
Woodleigh
S213 - AMG E 53 - 4MATIC - Premium Plus - Night Edition - Mild Hybrid Estate.
I had a similar issue with my W205 a few years back. During the 'B' service, the L/H passenger kick panel is removed to change the cabin filter this necessitates unplugging the ambient lighting cable. On this occasion, it was not reconnected.
C
curlyman
ok cheers will have a look :)
Headhurts
Norwich, Norfolk
Mercedes GLC300 2021
I had a 2019 E Coupe where similar happened I cured it by going into system and changing colours this did the job for me, plus the ambient light worked regardless of time of day.
Robin
BillyBoy
W213 E400d All Terrain
A 2018 car would be a W213 wouldn't it, or was it sat in a field for a long time?
Is it ALL the ambient lighting or just certain bits of it?
C
curlyman
hi yes w213 & yes all the ambient lighting could it be fuse 417 ? & if so where is it located if you know cheers
C
curlyman
hi any one know which fuse is for the ambient lighting cheers ? :)
AndySlade
Tadley, Hampshire
C220 Diesel Estate, Sports Edition
That looks like the fuse box in the engine bay judging by the translucent hydraulic reservoir I can see. Do you have a fuse box at the RHS end of the dashboard when you open RHS front door? Sometimes, not sure with your model there is a folded paper diagram giving all fuses and relay information on fuse boxes in engine bay, internal car (as noted) and rear fuse box behind removable panel on LHS of car. If so that will tell you all you need to know.
C
curlyman
yes they are the engine compartment,passengerside footwell & boot no paperwork in any of the boxes ? cheers:)
KennyN
Paisley
Can`t you just disconnect the battery ?
Only things that should need resetting on connection is the windows and possibly the presets on the tranny (if you can say that now-a-days)
K
C
curlyman
i can try that cheers found fuse diagram its not the fuse !!?
C
curlyman
Under carpet under fuse box ‍♂️
Srdl
Hampshire
GLC43 AMG 2018 (X253)
I assume it hasn't been turned off on the screen menu? Vehicle / Light settings / Ambient Lighting
DSK
CLS 320 CDI, S350 Bluetec
You can turn it off? Woohoo I’m turning mine off next time I use the car. I dislike ambient lighting, utter pointless nonsense.
DSK
you've not read your manual then :rolleyes:
I find that the ambient lighting in mine is so background that I hardly notice it, even at its brightest
Hell no! Not got time to read those 3 massive books!
The amount of gibberish in modern cars is just stupid. Can’t beat basic functionality done well.
no electric mirrors, seats, windows etc in your cars then ..... ;)
I didn't RTFM either but had a play with the dash cluster :rolleyes:
DSK
I could live without them!
www.ckinsurance.co.uk
