Another boring question re W124 instument lights
668hrn
Devon
320ce past w124 300d and 280e
I am slowly going through my "new to me" 320 coupe.The bulb has gone on the N/S heater vent. I can see the four clips lifting these does not help and they do not seem to depress. I can see plasic lugs on the righthand side of the vent. Do these hold the lamp holder? I removed the glove box lining and can trace the wire. What is the correct procedure here? Thanks for any help.
Bolide
www.w124.co.uk
BMW 525 Diesel Touring
The clips release by pulling them "up" into the vent. Use four thin screwdrivers to release the clips then wiggle the vent out
The bulbholder clips in and the bulb is a push fit
The first one you do is difficult but after that they're easy!
Nick Froome
www.w124.co.uk
668hrn
Devon
W124 Outer air vent removal
Hi, Thanks for that - 4 x small screwdrivers that fit the holes in the tabs did the trick. I held the lower two in my palm the top two with my fingers pull gently together then used my free hand to wiggle out the vent. As you say once done it is very easy. Thank you
