Another spot of trim corrosion
Capra
Gloucestershire
W204 2013 C350 CDI Pan roof
I had one of the roof trims replaced by mb last year. Today I spotted this on one of the window screen trims. I will contact mb again and see what they say. Has anyone else had this on a W204?
Had to reduce to 200kb.
sonic
Staffordshire
E350CDI, SLC250d, FJR 1300
Your attachment has not downloaded.
Looks like a stone chip, water has got underneath and started a bit of corrosion on the aluminium
Capra
Capra
Gloucestershire
There is no obvious chip, really smooth, I had some similar bubbles on the roof panels fixed last year.
Water has got in from the end of the strip and started corrosion ?
Capra
Capra
Gloucestershire
These bits must be prone to this type of issue, especially has this is the second area to be affected. I suppose it will need to be done at some point. I wonder if the just pull off? Some of this type of trim can be found on eBay.
A.J.
Norwich. UK
That is quite a common problem with a W204. Mine has that same problem both sides but it hasn't worsened over the last couple of years. You say it was replaced by MB, even though the car is six years old ?
Capra
Capra
Gloucestershire
The roof bit was done my mb last year for free, they said as the car was under full mb service plan they would do it.
Capra
Capra
Gloucestershire
I've been in contact with MB of Cheltenham, I popped down yesterday and had a follow up call today. They started by saying, yes we can fit as part of warranty, I then said great, but when I had informed them that I didn't buy from them, they talked about costs. Looks to be £85 to fit a new bit.
They thought the car was under three years old!! Maybe I should have kept quiet?? :confused:
A.J.
Norwich. UK
That would be a W205 then rather than a W204. What planet were they on ?? :confused:
They also think Staverton is Cheltenham :rolleyes:
Capra
Capra
Gloucestershire
I wouldn't mind but the guy I spoke to even took a photo that he said would be passed on the workshop manager, when I rang today he said, ok I will pass on the message and show him the picture I had taken. So nothing happened yesterday!!
