Any one out there know how to reset service light C180
molly
Ireland
1996 E200 W210 Saloon 1997 W202 C180
I have a '00 C 180 W202 model 1.8 petrol with a service light that needs resetting. If anyone out there would have an idea I would appreciate if You could let me Know.
M
molly
Ireland
Thanks coolpot for your fast response.
I have tried the sequence many times and I cannot reset it.
What I have on start up is a spanner sign with -217 across the screen where the mileage is displayed. After about 15 seconds after starting the engine the spanner sign -217 goes and on comes the mileage in its place.
Maybe Im doing something wrong - although I am following the procedure outlined.
Any Thoughts ?????? Thanks - This is a Fab forum.
dave.robbo
Gloucester
2004 SLK 350 R171
According to my handbook.. (Slightly different wording...)
Turn the key to position 2 and immediately press button '0' twice within one second.
Turn the key back to position 0 in the lock.
Press and hold button '0'. Turn the key to position 2. Keep button '0' pressed.
Hope this helps?!
M
molly
Ireland
Thanks Dave
Will Give that a go and see if it works.
M
molly
Ireland
Bingo - Worked a treat
Thanks Again Dave
BenzFan1961
Brilliant answers!
Now could someone please tell me how to reset the Schedule B service light on my 2000 ML320 ???
Thanks,
Dwight
Cole@MBS
www.mbssouthampton.co.uk
No !!!!!!!!
I think its ign on, press the reset button until you get the service milage up hold button, turn key of and back on still holding button for something like 5 sec,
Christ, got brain block tonight!!!!
Someone will correct me !!
BenzFan1961
Service reset for 2000 ML320
Thanks,
I'm glad I found this forum on benz enthusiasts!
I have two old Mercs at present that we are trying to sort out an 84 300SD Turbo Diesel with only 142K Miles on her and very little rust.
And our 2000 ML320 I do all the maintenence on the two (as much as possible) The dealer is my very last resort so we can still afford to eat!
Thanks for any help on this Shedule A/B Reset. Oh and my SRS light is on My Benz Dealer pointed it out and said they could fix it for about $500.00 then going on to say that it could spontaniously deploy at random if they don't fix it...my reply??? "Well I guess I'll just have to die in a firey crash then because I do not have an extra $500 laying about."
:lol:
blimsky
Just reset mine using the above method, spot on ! Another good one i found on an American site,
1 Get in and shut door.
2 Turn key to pos 2 and hold throttle to the floor for 15 secs, turn off whilst foot planted !
3 Release pedal and don't touch anything , dont open door etc, for at least 2 minutes.
4 Resets transmission to suit your driving, car is miles smoother changing gear, best thing i've come across in years !!!:D
squadron796
malta
W202/2000/C180
C180 service light reset
i have a c180 2000 facelift model.
It is giving me the service light on and cant turn it off
I have tried to use the method listed hereunder but still is On.
can you please advise what to do
Hope this helps?!
__________________
Dave.
W202 C-Class estate.
WG M-B
North west london
C63 Wagon in black
This is the procedure. Once you have completed the procedure you must keep button pressed untill you hear beep and new service data appears
horgantrevor
www.flickr.com
E220 CDI avantgarde c43//amg
i know this is an old post put will this work i must have a go ill get back to with an answer but has any one tried it
hi i forgot to say its a w202 i want it do it too
grahamcol
West Midlands
2001 SLK230, 2007 CLK220 CDI
Tried that loads of times and it just doesnt work, anyone got anything differant
My first C280 (W202 model, as yours will be) wouldn't reset either. Tried scores of times without success. Eventually had to have it reset by my indy using Star diagnostic.
