are these correct for w210 auto box?
There is no temp sender in the box as you say. the coolers are often linked to the rads
Pathfinder
Gourock
So how can STAR read the gearbox temperature ?
Wis does not say gearbox temp, it says engine temp, I am pretty sure of that.
mej
IoM and Languedoc
S124 1994 OM606, ditto OM605, ditto M111, W126, S211, W169
I would suggest that, due to the running of the box oil through the engine rad heat exchanger, engine coolant temp = box oil temp, but only after perhpas 15 - 30 minutes. The idea of passing the box oil through the rad is more to bring it up to operating temp more quickly than to cool it I believe.
I would think that is about right :D
Pathfinder
Gourock
So that changes everything on all past posts on dipping at 80c.
Advice should say dip ATF when engine temp is at 80c ?
mej
IoM and Languedoc
Provided the box oil has had time to be brought up to 80c as well I imagine.
Frontstep
T210 320cdi
The laser in these thermometers just aims it, they are infra red and subject to interference from nearby sources.
Pathfinder
Gourock
Double checked with probe thermometer. Same reading, 70c. Now convinced its engine temp that is the decider. Friends car reads less. 68c after a drive. C220.
AdamG
Bromley, Kent
S320CDI (2003)
Frontstep
T210 320cdi
Interesting and determinitive post.
shaggy
  • #32
i'm very interested in the outcome of this discussion
questions are only hard if you don't know the answer....... which is the norm for me
