nickdodds2008
- Sep 25, 2021
- Atego
Hi Guys, has anyone had the same issue and If so how did you overcome please?
Our 2001 Atego 815 clutch pedal has stopped returning to the top position after being depressed. If you pump it with the engine off it gains pressure but with the engine running it won’t.
There is just enough movement to change gear but it feels like it is deteriorating. Had it to a local truck garage whe said they had fixed it by changing the fluid but it has returned. Fluid reservoir is full and I cannot find any leaks.
Any ideas would be welcomed.
