Auto box problem
jross
Glasgow
The car would not come out of park,then the engine would not crank over,it keeps blowing fuse 55 underbonnet fuse box 7.5 amp.I had it checked and shows the auto trans switch has gone,were is this located and are there any place to get a secondhand part as Merc want over £400.The car is a 52plate c180 petrol.Thanks.
jross
Glasgow
  • #2
Any info would be greatly appreciated as been let down by mechanic last two days.
rpe2
Silchester
Look in the diy section. There is a write up on a starter/ fuse issue.
Pathfinder
Gourock
What is the auto trans switch? Maybe I know it as a different name?
jross
Glasgow
AA recovery ran a scan an stated auto transmission switch/steering position sensor.
If I change the 7.5 fuse the car will start but will not come out of park as it has blown fuse again,replace the fuse when car is running and I can select drive but fuse will go again and only give 1st or 2nd gear.All other fuses/elec working fine.
jross
Glasgow
Had another scan done today and it shows shift pressure control solenoid valve current supply faulty.Is the solenoid located inside the gearbox?
I think it is 30 and I will look it up in WIS for you
index.php
Yes you do it with the valve block dropped and not too bad a job at all:D
jross
Glasgow
Thanks again,will have a go and no doubt be back asking for help!!;)
I will print off the instructions for you and I can send them
jross
Glasgow
Thanks guys!!:shock:had a look at that early today and thought hope its no in there!!kerb side autos will have a go.:D
Pathfinder
Gourock
Malcolm and Miffy..I would also like a copy of the WIS instructions on the tear down of the box, Can you send them to me?
www.ckinsurance.co.uk
