auto trans fluid/gears 1and 2 stuck!!!!
sara786
hi,
I have visited this orum several times and find your information useful...
I have a feww problems that i hope someone can help with.
1- the auto gearbox wont go into 1st or 2nd gear,the rest work fine
2- atf fluid ,how can you drain it if you pour in to much..
please reply asap
many thanks
sara
Only by undoing the drain plug, or by using a suction device now in favour.
Are you sure about not going into 1 and 2
sara786
hello,thankyou for your reply but where abouts will the drain plug be?
and the device,how will i use it........the opening is tiny?
Im sorry to sound so dense....but halfords recommended that we use
castrol dexron III it was according to the manufacturers recommendation.
thanks
sara
sara786
hi,
thankyou for your reply the car that i have is the merc c180 97 model.
Im a little worried by your answer as i've already put it in the car and it is recommended by halfords,what i mean is they checked on their system and this is what came up as the best on recommended by mb.
How can i drain this,because there is a leakage and smoke from the car.
can you please reply asa you get this msg,im waiting for yor answer.
Your box should be the 722.6 box in 1997
722.600/601/604/605/606/607/608/609/611/614/616/617/618/629/634/639/660/661/662/664/665/666//661/662/664/665/689/695/699/996.
for new box 7.5 litres (+0.5)
MB 236.10 ATF A001 989 2303...MB 236.10 001 989 2103..........
Shell ATF 3403-M 115
The car must be jacked up and the drain plug removed, also the plug on the torque converter must be removed and drained.
When the correct fluid is put in, the level is critical and must correct with the engine running in park and hot
sara786
hi,
I can manage to put on a jack but how will i find the drain plug,and the torque converter,i dont even know where these are!!
Did i mention it was an 5 speed auto and the 1st and 2nd gears are stuck?
could this be anything to do with this?
I read somewhere mdels prior 1999 do not have drain plugs??
Is there any other way to sort this out without taking it to mb?
why is the car smoking and what is causing the leak?
can i check the level with out buying a dipstick?
I cant see how you can do this yourself, you will be better off going to an indie to do this, it is a fairly skilled job.
The other gearbox fitted was the 722.421
that uses
772.400/403/411/414/420/421/423/424/425/426/427/428/431/434/441/443.
From new 6.6 litres Change 5.5 litres. Fluid type
Shell Donax TA D-21666,21774.....Castrol TQD 22256....BP Autran MBX
Where in the UK are you
sara786
thankyou for all your help,im in central manchester.
Formby a very good guy that knows your car
S & R Motors at Formby,
Tel - 01704 834634
Ask for Ray
