B CLASS AMG - GROUND CLEARANCE HELP !!!!!!!!!!!!!!!!!!!!!!!!!!!
Merc Benz
B Class AMG
Hi everyone
Got B Class 65 plate AMG recently.Lovely car until i came across few half bumps on the road & noticed car scrapping over the bumps at the front.Please advise if anyone else has come across same issue & ideas to over come this.Don't want to loose car & would try anything to raise car to resolve the issue.Any help would be appreciated .
Merc Benz
bertb1
C220 amp sport 2013
Hello
Don’t go central to the bumps go 1 wheel on 1 wheel off method
Merc Benz
B Class AMG
Thats what iam doing at the moment but get fed up sometimes doing like this.Any way to raise the car bit to avoid this ?
bertb1
C220 amp sport 2013
Not sure my c class is the same I just avoid going central to the bumps
Merc Benz
B Class AMG
Ok thanks.May be someone might come up with an idea to resolve our problem
bertb1
C220 amp sport 2013
It’s not good going central as this puts a lot of pressure on the inside of the tyres and wheels
This can cause wheels to crack and tyre damage
It’s always better going 1 wheel off and one wheel on
Merc Benz
B Class AMG
oK tHANKS , WILL CARRY ON LIKE THIS FOR TIME BEING
V6Matty
Newark, Nottinghamshire
When you say it’s catching is that as you drive on or off the hump? My wife’s a class catches the mudguards driving off any traffic calming and I’ve found it’s quite normal with the avantguard spec due to it being 15mm lower
Merc Benz
B Class AMG
It happens when i drive over half bump (two wheels on side & small hump in the middle). Ok to drive on normal humps.Might be normal as per spec on AMG line, but bit reluctant to go over them as might end up damaging sump. Any ideas how to raise little bit ?
You're unlikely to damage the sump as it's between the wheels. It will be the bottom of the bumper and perhaps the undertray.
Straddling speed humps is bad practice as it damaged wheels. Far better to put one wheel or the other over the middle of the hump and drive a bit slower.
V6Matty
Yep, +1 your going to be catching the very lowest part of the undertray, live had a look at my wife’s before and and it’s scratched to hell, including some deep gouges, nothing wrong with the car and nothing to worry about.
However as the others have said, put one wheel over the centre of the hump to save your suspension, wheels and tyres.
A.J.
Norwich. UK
So does cornering!
