B180 CDI 2005 IDLE
Anthony Cutts
B180 CDI 2005
Hi All,
I have recently purchased a B-Class B180 CDI Automatic - drives great with no "real problems" no knocks or bangs etc.. but..
I have an issue with the car when it's idle, it is making a noise like it wants to stall. I have plugged into the ODB port and it shows no active faults.
I first thought it was something to do with the Mass Airflow sensor as when this was unplugged it went back to "normal" idle.. I have since changed this part and it has somewhat made a difference certainly it drives alot better... but I still at times notice the problem especially when sat stationary at idle.
Can someone possibley give me any other suggestions what else it could be?
Anthony
mattkh
England
A160 W168 1999 1.6
Did you change the air filter when you were at it?
Exp21
Italy
s204 C200 CDI Blue Efficiency MY2012, w245 B200 CDI Facelift
Hi. I have the same engine and years ago had a very rough idle, especially in winter. Then I had to do the head gasket (due to a oil leak) so they cleaned egr valve, mixing chamber, intake manifold and it came back to regular and quiet. Probably it's the egr slightly open at idle due to clogging? Hope it can help
ajlsl600
france
Do let us know the cause fix,when sorted.
uivilstyle
Mercedes Benz A180 CDI, W169
Hello,
I have the same issue.
Did you sort it out?
What was the cause?
Thank you!
