Bad Starting E320 CDI Vreg
stevieg
My 320cdi will start then stop on first turn of the key it then will not start again without a long period of cranking .however once started will start 1st time for the rest of the day whithout any hesitation .the glow plug light is illuminating as it shoud and the engine runs very smoothly without any misfires whatsoever
jibcl500
Cambridgeshire
CL500,ML55,SLK280
Sounds like air leaking into the fuel pipes somewhere, have you had a new fuel filter fitted recently.
jib
stevieg
thanks for the clue i think it had oil and filter change in november but not sure about fuel filter .if it is air leaking would this not affect starting at anytime
Daeths
North Kent
T212 facelift, 2013. A few toys including pan roof, 19" rims, Harmon Kardon, nappa, privacy glass.
nthe system is vacuumed it will draw air in overnight and each morning youare cranking to 'bleed' the system.
You will find a lots of posts on the forum covering this and Parrot of Doom covered it well. The usual culprit is the o rings on the fuel pipes. To be honest if they are orginal < iwould replace the hoses anyway, would guess they are nicely yellowed and brittle and will go themselves eventually.
rec get the proper Merc parts at about £20 average per pipe
Parrot of Doom
Manchester
Keep the fuel tank full to the top and try to park nose down overnight. If that clears the problem then its definitely an air leak. Another way to tell is just to look for air bubbles in the lines around the fuel filter, in the morning when you're cranking it.
www.W140.co.uk&www.r129.co
