Ball Joint or Money Making Antics?! W205 C220D
onefortheroad
uk.
Also, on the oil filter for this car...I seem to have received a plastic screw with a rubber washer in it.
I thought when the car has an oil change it just needs the copper washer replaced on the screw...
Possibly a plastic sump ?
onefortheroad
uk.
Price update for anybody who’s interested...
Front lower arm is £100 from Euros or £210 from main dealer.
Fittings can be reused from the old arm
£65 with code . Star line brand ??? Really .
O
Omz2020
C220 D W205 2015
  • #23
Yeah that’s what the dealer told me, only one way to find out!
On a better note, just changed the air filter and dust filter. Surprisingly simple job for a noob!
O
Omz2020
C220 D W205 2015
  • #24
I wasn’t sure if code was applicable for this but thanks for heads up. If I end up getting it done I’ll check on that
D5meister
C class 2014 2.2D 7Auto
Put a very thick lucas industrial/marine grease in.
Due to lack of clearance the nipple was replaced with a flush screw.
Silent now, but for how long?
O
Omz2020
C220 D W205 2015
  • #26
Wow...looks complicated. Thanks for the detail. I’ll have to wait for my breaker bar before getting the wheel off and see what’s going on there
star
Reading
Smart + others :)
Neat bleed nipple install, how did you re attach boot?
Just keep in mind, super cheap arms from Euros don't last anything like as long as MB oem.
D5meister
you need a vice . The wider end of the gaiter retains easily on a lip.
The fiddly on is the narrow end, it has a metal band (bit like key ring size) you seat gaiter in a recess on ball joint shaft low down. This recess is deeper to ease fit. Put band on, slide banded gaiter up to final position.
The metal band( has to be correct way) up as shaped. To get gaiter end thru band i use thick string wrapped bout 1.5 times around. Keep pushing band on an peel /pull string ends and pregressively flips gaiter over metal band. Now tease up to final resting groove/recess for use. Done.
Fiddly. Bit like how they used to put windscreens in with thick cord around the rubber gasket around the window edge and squirt of lube.
Only for garage mechs/hobbyists/tightwads, like me! Everyone else has to drop em at the dealer and not blub.
star
Reading
Smart + others :)
We have replacement boots and the tools to fit but some of the later boots are peened in, so can’t be secured with a clip.
D5meister
My one is from 2014 with clip. Dont know what year they change.
D5meister
There is a vast amount of these going wrong at 40k miles up. The ball joints on my last car have done 260k miles and are still going!
Some say they are cast into the arm.
I think they are pressed in.
D5meister
The merc arms dont last either, hence this thread.
Aftermarket cant be any worse.
If u want 3 years plus, meyle or lemforder all day long.
D5meister
A good grease, very tight, good on sliding surfaces is this. Its in my bodged joint. 20200529_211226.jpg
ajlsl600
france
Think that's somehow too much for a ball joint, and an arm that I didn't need quick ebay search for my MG shows from 12 to 20 quid for a circlip retained replaceable ball joint.
ajlsl600
france
Thinks that near Dtf design, I have yet to change a ball joint on my w208 160k miles and if need comes I won't complain at 19byrs!
40k miles and 100 quid a side for 1!!ball joint I sure would.
D5meister
Merc just want to cost reduce assy time.
So there are 2 ball joints and 2 bushes in one throw away arm.
There will be a replacement ball joint out there that will fit these. Plus a way to pull the old one and press the new one.
D5meister
186 quid plus fitting. Per side.
They only last bout 5 yrs approx.
ajlsl600
france
Only way I see to improve odds there. Drill /fit grease nipple before fitting replacement arm. And that's If there is enough material to securely tap for nipple threads?
D5meister
I agree.
Yes plenty for M6 nip
There isnt enogh room to leave nip on, i put M6 grub screw in.
www.ckinsurance.co.uk
