BAS, then ABS light
SteveX
Well, I'm not having much luck, today I pulled fuses checking for a stereo problem, and pulled the stereo, I found out the front speakers are not working; strange.
Anyway, I changed out the drivers fore / aft seat motor today, it started working again but was smoking! I assume it was burning out so I switched it, now really pleased I have a working drivers seat, but on starting the car I've had the annoying:
'BAS Visit Workshop'
followed by
'ABS Visit Workshop'
The car was running fine before pulling the fuses, checking the stereo and changing the motor.
I really can't fathom out why this has started happening? I've pulled all fuses under the bonnet and checked which ones are empty to make sure I didn't accidentally put one back wrong, but no joy.
Not sure why on earth it's doing it now, the car hasn't moved since I serviced it last night, and when I started it a few times last night it was perfect.
Since pulling the stereo out, checking fuses and changing the drivers motor I've got these warnings :(
Any help would really be appreciated as I'm pulling my hair out.
Cheers,
mersum1es
Finland
What car?
Basically doesn't matter, BAS/ABS are always coming after battery/voltage disconnection. Turn wheel lock to lock, should clear the warning lights. Then norm the windows.
SteveX
SteveX
Guys, I if you were here right now I would buy you a beer each and give you a big hug, I was feeling so defeated after working hard on fixing things the past couple of days and then this happening lol. It's working!!!!
Thank you soooooo much.
