Bi-Xenon failure - not the bulb....
Hotdatum
London/Somerset/Portsmouth
E Class Estate 320CDI (2007)
E320 Estate AV 2007 - drivers side dipped headlamp is out, switched in a new bulb and no joy. Garage say it must be the igniter unit and say its about £500 all in to change.
Does that sound about right????
(only had it a week - bugger!!!!)
Cheers a guys
Tom
Naraic
2005 CL500.
Cheers a guys
Tom
Go on Ebay and pay about £30 for an ignitor. But it might be the ballast...also on Ebay for about £30.
http://www.ebay.co.uk/itm/mercedes-...CarParts_SM&hash=item46009de912#ht_500wt_1156
http://www.ebay.co.uk/itm/Mercedes-...arParts_SM&hash=item4ab3b8be66#ht_1534wt_1270
As the above questions, dealer or private,, and on Ebay very cheap
As above they have no choice in this but to fix it :D
H
Hotdatum
Does it matter that it was working when I bought it?
Thanks for the eBay link - if I have to pay I'm going down that route. As ever you guys are genius!!!
Nope, it matter not that it was working, if you get a fault this quick you are covered under all laws
WG M-B
North west london
C63 Wagon in black
It's pretty quick and straight forward to change both the ballast and the igniter from one side to the other to test them. I would have thought your garage would have done this in order to give you an accurate diagnosis rather than just assuming
H
Hotdatum
Ok - it was water ingress into the ballast/headlight unit which has corroded the connectors to both. Solution is a complete headlight switch. £474 for the unit (plus VAT!!!!) and 1 1/2 hours labour.
The garage I bought it from are paying parts and I'm picking up labour as I got the car in Ely and I can't be bothered to take it back to them (from Portsmouth).
All in all I'm happy!
Cole@MBS
www.mbssouthampton.co.uk
Funny that, we see the same fault yesterday!!!!!!!!!!!
