Big Hi from Norfolk!!
theoddbod
theoddbod
Norfolk
www.oddbodscleaning.co.uk
E-Class 320 CDi Avantgarde
  • #21
Cheers Andy, I know what your saying - I was (very) surprised to see this - but reviews seem good and at this stage its only a diagnostic - so if they c*ck that up I will stay clear
thx for the link personal reccomendations are always welcome - the car tells me I'm due a D service in 1500 miles so I would be quite happy to try them ( Even tho, its over the border in bandit country :) )
Darran
You also have (a bit further) Alex Crow , Mercedes , Stwomarket . Who is a seriously good MB Indy
A.J.
Norwich. UK
Darran
They won't scalp you !! :D
theoddbod
theoddbod
Norfolk
  • #24
maybe, maybe not - but I will still stand out as I have the correct number of fingers and toes :D:D
400ixl
E250 AMG Sport Convertible
Is that 10 fingers and 2 webbed feet?
Or should that be 24 with 12 fingers and toes?
A.J.
Norwich. UK
Don't need webbed feet out here in East Anglia Stu, this is allegedly the driest part of the UK ;)
theoddbod
theoddbod
Norfolk
  • #28
Results are in !!!
4 Errors -
Throttle position valve
Glow plug relay unit
Turbo Actuator
Exhaust Back Pressure Sensor
these were cleared with the Turbo Actuator and Exhaust Back pressure codes immediately
they have said they have a "specialist" who can repair the actuator without replacing the whole of the turbo
looking at 450 for the work
I did read on a thread a chap did just change the actuator but still had to buy a complete turbo unit
Darran
Results are in !!!
4 Errors -
Turbo Actuator
Darran
Both actuators and ebps do crop up regularly with the om642 engine . You could as an outside chance try changing fuse F44 which is in the engine bay by the brake fluid reservoir , it's a 15amp fuse that does cover (I believe actuator and inlet port motor ) .
I recently took my actuator off after having some fault codes , looked inside it , found none of the broken wires that are a common failure point . Cleaned it out with electrical spray , and put a tiny blob of high temp grease on the worm gear and bingo fault codes disappeared . That was nearly a year ago .
As far as I know you can buy a reconditioned actuator for £100 ish , and they don't take long to fit , but I don't know if they need to be calibrated to the car by MB Star computers ?
If you are handy , the ebps is about £50 new , but you could try cleaning it out as there is a tiny hole underneath it which blocks up .
theoddbod
theoddbod
Norfolk
  • #30
Electrics baffle me!!
back in the day I'd tackle almost anything on a car but now....
need young mans eyes
Just change fuse F44 , anyone can change a fuse . Worth 50p
theoddbod
theoddbod
Norfolk
  • #32
Hey! - have you looked under the bonnet! - I did and muttered something like.... oh dear me- closed the bonnet while slowly backing away :D
No I'll have a look shortly - what style fuse do Merc's have ?
Darran
Darran
It's a large flat ,blue , 15amp fuse , if it's the same setup as mine it's back right of the box , behind one of the square black relays . Swap it with another of the same rating if you haven't got one
theoddbod
theoddbod
Norfolk
  • #34
Just an update - after a little bit of 'faffing' I returned the car to the sales guy who has sent it to an independent Merc garage for the actuator to be done ( I did threaten to return it and just get the cash back - but I'm a bit of a softy and I love the car - they are a real power house - when not in limp mode :p )
it's due for collection today so hopefully I will have her back and zooming around from tomorrow :)
Darran
Darran
Well played buddy :D
sonic
Staffordshire
E350CDI, SLC250d, FJR 1300
Welcome, regarding the SatNav update discs are about £100 & issued every 12 months.
Its not a particularly good system, its quite slow & no speed cameras.
I run Waze on my iPhone. Its free covers the whole of Europe, & uses very little data.
theoddbod
theoddbod
Norfolk
  • #40
Thx Sonic
I use Navmii but until I get a bluetooth thingamy gig sorted out I do use the Merc sat Nav :confused:
