black death injectors
tre123
sussex
E320 cdi estate
Hello Guys i posted about fumes in the cabin and you told me about black death!
Well i took the car into a local garage that is supposed to have a good reputation on diesels
tyhe car had been running really well except the fumes were horid if vents were not closed.
they reseated the injectors and then the car would not start at all.
so after trying for a day to get it going they sent to injectors to a test bed and the results from it were that all 6 were in need of repair one had a broken magnet others were contaminated their suggestion was maybe bad fuel or bad mix?
they want £95 for each one to be overhauled -BUT that wont guaratee me that the car will be ok
SO any suggestions welcomed
its a 320 E cdi estate
thank you
rob
T
tre123
sussex
E320 cdi estate
thank you i shall give them a ring
T
tre123
sussex
E320 cdi estate
Thank you i rang them and it`s £140 each so the £95 to have my ones done locally is actually cheaper so i am having that done now.
just hope the car starts after all the outlay.
Maybe i shud of just put up with the smell in the car at least it was going ok!
T
tre123
sussex
E320 cdi estate
hi all i had the injectors refurbed and in they went -running lovely for a whole 12 miles and then BANG! number 5 injector is 4 inches in the air damnit
so i am waiting yet again for a repair
A
andy@pcd-ltd
Sounds like the threads in the head have been stripped.
Do you know if they are going to repair the head or try and get you to pay for a new one.
Are they charging you for this repair
Njmotors2011
cheshire
w210 96 3.0d w901 311cdi ml 270cdi Sierra sapphire cosworth
Hi this is an easy job you hire the tool off ebay to put in a new thread and this is better than mercedes did in the 1st place garages will charge silly prices for the work.
A
andy@pcd-ltd
I have a guy who comes around and does those repairs for me and charges me about £70 to do it and he supplys a bigger bolt etc in the price.
Never had a repair he has done fail after
ELGRINGO
fylde coast
e230 c180 sl280 brabus a190 smar cart
Hi we fit inserts which still allow original bolt to be used, or can drill and tap for 8mm allen key bolt.
mersum1es
Finland
Helicoil, quite easy to install and can use original sized bolt (original injector clamp also fits without modification).
jasonyw
Banned
c180/1997/1.8;W211/2005/E200K
sam/unit will do it for you.
T
tre123
sussex
E320 cdi estate
thats what had been done new threads fitted and nuts on top
T
tre123
sussex
E320 cdi estate
GGGGRRRR!!! it has poopped no 3 injector now
