Blue sensor on front brake
Pweb2203
E400d 4matic 2019
Hi all
Had loud squealing and loud clang from front wheel last night. Assuming just a stone caught between disk and guard. However I noted that there is a blue sensor one driver side front brake only. What is it and is it correct that only on one front wheel?
just interested
thanks
Hi all
just interested
thanks
Brake wear sensor , yes it’s often only in one wheel . May be an aftermarket if it’s blue ?
(Although on a 2019 car I doubt it’s aftermarket )
P
Pweb2203
E400d 4matic 2019
Thanks for the quick reply.
star
Reading
Smart + others :)
Lots of different brakes sensors, blue is one of them.
EmilysDad
Bury Lancs
ML350
And opposite sides front & rear on my R Class .... no idea with my ML .... never looked :rolleyes:
onefortheroad
uk.
Me -2019 GLC 350 coupe AMG line. Mrs- 1.2 vauxhall Corsa 2021 ,orange with a black roof. .
My 04 e320 had sensors on both fronts and only 1 on the rear . Is that classed as triangulation?
EmilysDad
Bury Lancs
ML350
I suppose if manufactures can save a quid here & there they will. My Omega had 2 sensors at the front (none at the back) but they dropped a sensor on later cars. Better set up too .... the sensor we t open circuit rather than to ground & only reminded you each ignition start .... not every bl33ding time you pressed the pedal
pgh13
Nr Leamington Spa
E320CDI 2004 - straight 6 diesel
I was surprised on W211 to find the left and right front have different shaped connectors.
Why stock one part when you can stock two?
Cole@MBS
www.mbssouthampton.co.uk
That’s cause the near side is a 50% wear sensor So the hole in the pad is different to the O/S
