Blue smoke from exhausts on tick over
Hughesey
South Wales
Cls 320 CDI
Recently whilst caught in a traffic jam I noticed a worrying amount of blue smoke issuing from the exhausts, it doesn't happen not that I've noticed whilst driving at normal road speeds, the car was stationary for approx 30mins but disappeared when returned to normal driving. Leaking injector???
Blue is normally oil and leaking valve stem oil seals used to be the culprit
Hughesey
Hughesey
South Wales
Cls 320 CDI
Thanks for the replies, would the fact that the car isn't losing any power and is still responsive have a bearing on any remedy?
It's a diesel so unlikely to be valve stem seals. Petrol engines are far more susceptible due to manifold vacuum drawing the oil down.
John Laidlaw
Wirral
Land Rover Discovery 4
Little too much oil?
Turbo seals on the way out ( but then you’ll notice a power drop and responsiveness)?
Edit: forgot to mention quality of the oil itself- changed recently or not?
Hughesey
Hughesey
South Wales
Cls 320 CDI
That's a good point John as the service history is a bit wooly after 2016, having said that, the info in the car says 15500 miles before service E.
Uncle Benz
West Sussex
Mainly Mercedes
How many miles on it? It might be worth checking the pcv valve on the back of the offside cylinder head for blockage. I have found that OM642 are prone to dripping fuel injectors. The smoke builds up at idle, and it stinks. It has a tinge of blue to it in my experience, possibly because it starts to wash the bores. It will quickly disappear after a few hundred yards of driving. Any decent Indy can pull the injectors and get them tested. Any dripping is immediately obvious under test. I'd certainly do this before considering replacing the turbo or any big tear down work.
Hughesey
Hughesey
South Wales
Cls 320 CDI
Mileage has just turned 99,000
Hughesey
Hughesey
South Wales
Cls 320 CDI
Morning guys, an update on the engine issue, all the injectors passed but there's oil in the turbo lines, thoughts???
If you mean the air pipes, then that's normal, to a degree. If its swimming in it, then its not normal.
ajlsl600
france
how does b/fluid get into the engine? only way i can imagine this is thru servo vacuum line and then only as far as vac pump ?
