Blue Smoke on Startup 320 CDI 2001
Frontstep
T210 320cdi
Could someone fill in some more alternative things for me to look at I know there's a few but I am sure I have missed something.
The car smokes a lot on startup only not over-run, its bluey grey and points to oil with no smell of diesel.
Its had injectors full recon set, oil separator,glow plugs and module etc
Starts straight away within seconds and a bit lumpy but clears, then runs well.
Have you checked for movement on the turbo spindle?
EmilysDad
Bury Lancs
ML350
blue smoke on start up is usually/often a sign of worn valve stem seals .... oil leaks passed the valve seals, generally over night, into the bore hence the smoke on start up.
F
Frontstep
T210 320cdi
Thanks the valve stem oil seal suggestion I thought I had dealt with by the "over-run" observation.
As I understand it oil is sucked down past the seals and into the combustion chambers.
You then put your foot down and "open the throttle" then small amount of oil is then instantly burnt with the fuel/air mixture giving you the quick puff of blue smoke.
The turbo bearing play I can't to be honest get my head round,
why only on startup ?
When running any small amount of oil coming past the seals is picked up and burnt with a large volume of air. When you shutdown any oil in the inlet tract from a bad seal can pool at the lowest point, such as a valve or cylinder (if a valve is open). When you restart the pooled oil gets drawn through and gives blue smoke.
If a seal is only seeping manifold pressure from boost will also push against any seep, but at idle/startup that pressure isn't there.
abazem
Islamabad
Mercedes E270 cdi /2004/OM647
So would it be a good idea to put car on idle for 2-3 minutes before shutdown?
F
Frontstep
T210 320cdi
So an inspection of my pipe work and Turbo seems in order, thank you,
surprisingly I have a lot to do, I have taken on some covid projects as I call them.
One minute is sufficient to maintain turbo health after a hard drive.
If it smokes then investigation is required to see if the seals are leaking.
Simply idling for 2 minutes won't fix it, just hides the symptom.
F
Frontstep
T210 320cdi
The Turbo has finally been changed and the smoke already a lot better thanks for the pointers.
The car needs a throat-clearing run to burn out the oil.
