Bluetooth adapter
Bracknell
E280 2005 CDI
hi guys I’ve just changed my c class to an e class and wondered if I can get a Bluetooth adapter to fit this see photo
If no one on here can help , give the guys at Command Online a ring , they know and supply everything in this area .
I'm going to guess a Viseo 3000 will be required... (Good luck finding one at a sensible price).
I hasten to add I'm no expert.
ZZZZ
This is a Nokia cradle, you need to remove it first (press the little button in the bottom right-had corner as pictured).
You can then fit either a Mercedes OE or a Viseeo adapter, however I'm almost certain these will not stream music, only allow calls via bluetooth.
Chrishazle
Nr Ashford, Kent
GLK is correct, the little button in the bottom right releases the Nokia phone adapter from the UHI connector in the arm rest (IIRC while pressing that little button you move the cradle backwards, not forwards, but I may be wrong). The you can fit either a cradle specific to your phone (I have one for my iPhone 4) that charges the phone as well as linking to Comand and the phone buttons (and is a bluetooth adapter when the phone is in your pocket instead of the cradle), or a bluetooth adapter like Viseeo. However, do not expect music streaming etc from your phone - even importing your phone book can be a bit of a mission.
Having said that, I find the hands free with my cradle, whether or not the phone is in it or in my pocket on the back seat, is excellent.
As said above, talk to comand.co.uk, they know more about MB ICE type stuff than MB!!
Darren Beckley
Bracknell
E280 2005 CDI
Hi I’ve removed the Nokia a cradle just waiting for amazon to send me out Bluetooth one
I think command on line is based very near where you live if you get stuck
Botus
S500/2010/500
very near
they are in lightwater.... which depending on where in Bracknell could be 4 miles away
