bouncer
1998 W202 c200 sport
I put some bags in my boot and closed the lid as normal, then I forgot I needed something out of one of the bags. I tried the button on the key fob as normal. . . . nothing, ok I thought I will use the release button by the gear stick. . . . nothing. Last resort I will use the blade that's inside the key fob.
Yes you guessed it key only went in half way. . . lock full of gunk.
Left it for a few days as I was off to see Ian at 124 Works for a MOT and a bulb. Ian kindly freed off the lock after 20 mins (in the rain as the workshop was full) Sorry Ian.
Car failed the MOT. . ball joints and steering damper, but all kindly sorted by Ian. Forgot to get the boot release sorted by Ian. :Oops:
Ian didn't charge me for freeing the boot lock off either. . . or the bulb for the number plate light.
So any ideas as I fancy having a go myself. Symptoms are:-
Boot wont open from button by gear stick
No red light on said button when the boot is open by the key
There is a funny noise from the petrol filler flap / door that can only be described as woodpecker when I lock it using the remote key. The woodpecker only lasts for about a second.
All the other doors work and lock fine off the key fob.
Where should I look first?
