Bouncy A-Class
Helmet Vonthrob
Hampshire
A-Class, various: 160/170
My girlfriend has an A160 with alloys, good tyres, pressures checked but it just seems a bit wallowy, not dangerous but a bit less controlled than we would like. Looks like new springs on the rear so (hopefully) no problems there.
I know that these things aren't the most stable and that they only just passed the 'Elk Test'.
What are the common consumables and how common?
Also, if I go for replacement shocks - what make is best?
Cheers
nickh
You don't mention what year A160 you have,
jack up the rear of the car and see if you can move the rear wheel in & out, (If so you need new rear suspension arm bearings) a common problem apparantly.. certinaly gave us the the problem you mentioned..
I have just replaced these on our A class (2000)... much better now...
probably cost £200-£300 in stealership to replace, i did mine myself (£50) and 5 or so hours of hard work, cos the old ones were disintegrated and all rusted in place.
I believe the shocks fitted are Bilstein sport..
may be worth getting the tracking checked at a mercedes dealer (although this may not be cheap either)
