Brake pads or shoes
mancman
cheshire
GLC 250D
Hi folks, driving to work tonight the brake shoe symbol came on the dashboard, how long roughly before they will need changing because I'm sure it's not critical to change them asp or is it, thanks for any replies.
1000 miles of light driving about the max :D
mancman
mancman
cheshire
GLC 250D
Thanks Malcolm, I take it that it's the front pads that req changing would that be correct.
Naraic
2005 CL500.
You have wear sensors on the front and the back. So, could be either...most likely front though.
teddycatkin
cheshire cheese country
All the lights do is tell you the pads have worn down to the sensors---the longer you leave it with the light on you will wear down the sensors too!
(ECP with MB owners discount of 25% is a good deal at the moment )
toby1
West Berkshire
1997 SL500 R129
If you hear a grinding noise you've left it too late.
mancman
mancman
cheshire
GLC 250D
Thanks guys,had my car serviced in April this year at mb, front was 25% worn rears were 10% worn I have only done 2000 miles since then sounds like they have worn very quickly. Any thoughts on this ?
Both types of sensor have to be replaced once the warning is on.
www.W140.co.uk&www.r129.co
