Brake wear w211 e220
atlantimd
Ireland
mercedes benz E220 cdi estate W211 facelift 2008. Mercedes SL320 R129 1996.
Hi All I hope someone can help me with this
About 6 months ago I got a Brake Wear warning on the dash brought the car home and as it was Saturday afternoon I got a set from the motor factors and replaced the worn set. The Brembo set did not have wear sensor and the old one was worn through so I expected the Brake wear message to still show. I purchased 2 wear sensors online and fitted the one (only fitted on R/H Side) at the rear. I still got the brake wear message. I have done some research and I understand that the system is just open closed circuit type and has no reset in STAR Diagnostic or as I have IcarsoftMB. I have removed rear wheel liner and checked wire continuity back to the connector that is going inside the car and there is no wire break.
The wear system worked as it should “It warned me of rear pad wear” and there was metal contacting the disk but all has been replaced.
I have checked the front and all looks good I am wondering has anyone came across this before or does my Model have an interface with Diagnostic system and need a reset. I have a test coming up soon and its a fail item.
Pullman
ESSEX
1981 500SL_1999 500SL_(2002 CL600 sold) 2003 500SL
Have you tried service reset proceedure? ... obviously you've fixed the problem and for some reason it hasn't registered it ... how about disconnecting and reconnecting battery after couple mins?
Sent from my Nexus 5 using Tapatalk
atlantimd
atlantimd
Ireland
Thanks Pullman I will try reset and battery Disconnect Tomorrow. It is due a service and I don't want to loose all info so hope battery reset will do it.
You could try fitting the other wear sensor (you said you bourght 2 ) in case it was faulty ?
Or swap the new rear with the front wear sensor (if they are the same ?)
atlantimd
atlantimd
Ireland
Hi Wighty I have swapped sensors, still the same issues
I replaced pads earlier this year on my R Class (months before it was part ex'd o_O) and the sensors were two wires that went CLOSED when they shorted out across the disc, so, though I didn't try, if the sensor is removed all together, the warning message won't appear. This is the opposite of my Vauxhalls in that the sensors were a short across the two wires & when the disc wore through the sensor it went OPEN circuit
atlantimd
atlantimd
Ireland
Hi Disconnected battery no fix. Icarsoft shows current brake lining thickness 0mm, rear axel - 100% brake wear sensor = activated. I must have the only car that needs STAR to reset after brake replacement
atlantimd
atlantimd
Ireland
New Sensors have continuity (Shorted) and presume go open circuit when pad wears. I put meter across nee sensors and got 0 closed circuit
atlantimd
atlantimd
Ireland
Issue resolved. Well the confusion was 1 of the new sensors was open circuit and the front was open circuit ( pads still ok ), when ever swapped around there was always 1 at fault. Thanks for your help guys. I suppose checking new sensors for continuity is key here.
