Brakes callipers name plate
Colinmagnum
E class cabriolet 350 blurted
Brake calliper front ,Mercedes press on name plate ,E class 2015 Does it serve a porpoise to the brakes or is it only there for show ? Thanks
Hello and welcome
No, it doesn’t serve a dolphin at all… you can get the stickers, paint the callipers and then put the stickers on If you don’t have them from Mercedes originally.
C
Colinmagnum
Hi The whole plate is missing told you can not buy plates separately you need to buy the whole callipers.Can you run without plates or should I insist the whole callipers are replaced ,costly.Bought car from Mercedes’ Thanks
EmilysDad
Bury Lancs
ML350
I'm sure I've seen these in the past ..... buggered though if I can now find them ???
Frosty149
Garden of England
W207 2014 E350 coupe Bluetec D
You
the anti rattle clip on one of my front callipers was broken and the subsequent ticking and clunking noise drove me to despair!
I’ve recently fixed it and to be honest, I don’t recall if the push in plate was actually relevant to the calliper’s function other than cosmetic finish?
I painted the ‘body’ of the calliper whilst doing the brakes - they are visible through the wheels, and it’s tidied up the appearance a bit.
Given that the vendor is a dealer I’d insist that the callipers (brakes) were complete and therefore ‘safe’ - who knows what has been done prior?
Mr Greedy
Leicestershire
E350/2011/OM642 265bhp
I have a w212 with the single piston caliper on the front if this is the same as yours. The dark, flat metallic plate with Mercedes Benz on is made by TRW and has a TRW part No. stamped on the back, but it's not available separately and if you contact TRW they will act as if you are mad and asking them to explain why the moon is made of cheese.
For the calipers I have, the plate is cosmetic only, and it's either source some plates someone else has had knocked up, get some made yourself, or buy a new caliper.
JBell
Torquey
C350 CDi Estate (GAD Edition)
I am missing the one from my front drivers side calliper, makes no difference at all, purely cosmetic
C
Colinmagnum
Hi TRW tells me can’t get name plate callipers are made for them in a factory in France and sent directly to Mercedes Factory.Does anybody know name of factory in France?Or the number stamped on back of plates?Thanks
Mr Greedy
Leicestershire
TRW 32337198
C
Colinmagnum
Thanks for part number will try TRW and Mercedes again
Mr Greedy
Leicestershire
You won't have any luck. I chased this down before. I even mentioned the green aspect of being force down a caliper purchase vs replacement plate and pointed out that this is totally opposite to the Daimler environmental policy that is supposed to be applied internally (I worked for a supplier, and the policy was flowed to us and we had to adhere to it). It seemed like Merc weren't at all interested in taking it seriously and the person I spoke too wasn't even aware of the group policy (that suppliers get smashed for breaching, yet the Daimler group hadn't heard of it).
The best option would be to find a local metal working specialist and get some made up. I'd take a couple for circa £50 the pair if a group buy was organised.
ajlsl600
france
If really matters make em urself. Or run around breakers no one interested in bits of these days, buy unit or p off is the norm
If twas buyin another modern car my 1st question,how much are headlight units.? Likely to be end of my interest in that..
Craiglxviii
Cambs UK
Try these guys…
C
Colinmagnum
mrkjennings5
New Registration
SLK
Does anyone have a spec or a drawing, I think I can have the manufactured painted & vinyled
