digcot65
- Jan 15, 2017
- Location
- worcestershire
- mewrcedes w2203 2000
I have a 1980 Mercedes 450 SLC ,the brakes have always had a lot of movement in the pedal ,once the engine is running.I have just replaced the master cylinder and fitted new seals to the front calipers and new pipes.I also bled the cylinder itself when bleeding the brakes.when checking the system, I also clamped the pipes on the front calipers and the brake pedal didn`t go down as far as usual.Any ideas,other mercedes owners say how good and solid the brake pedal is when set up correctly
