C180 running temperature
Cyber Sleep Walker
Hello,
I've noticed my C180 is hitting temperatures in excess of 100C (around the 110C mark) is this normal ?
Thanks in advance,
CSW
Splatt
That Nook Shotten Isle of Albion
Does it vary between sitting in traffic and out on the open road ? My gauge sits at 80C constant but they are not that accurate as to the actual temperature.
SQ_W211
W219 CLS55 AMG
we have a switch on our cars which triggers the fan to kick in if the temperature reached 100C. If yours always sit at 100C then get it looked at as it could be faulty switch.
Normal temp should be 80C but it can climb from 90 - 100C when its hot outside and your car is standstill in traffic. When it reaches 100C the fan should kick in to cool it down to 80 - 90.
If you only have the one engine fan then the thermostat opens at around 87C and the visco fan cuts in and speeds up.
Any electric fan on the rad if fitted does not open till 100c.
You should check that the visco is running at full power by seeing if it will slice a carrot at 95C
Splatt
Malcolm, why don`t you buy one of those Mouli kitchen appliances to slice your carrots ? Lot easier than starting the car up every time. What do you peel your potatoes with, put them in the hub caps ?
SQ_W211
W219 CLS55 AMG
Bet he never though of that before
You just saved him alot of fuel from warming up his engine
Thanks for the idea's ,so thats the fish on the exhaust manifold, the carrots from the fan and some sand paper in the hub caps to peel the spuds, just got to cook them :D:D
SQ_W211
W219 CLS55 AMG
Your engine oil is warm enough to cook everything:cool:
Cyber Sleep Walker
Cyber Sleep Walker
I think it tends to creep up more sitting in traffic queques and the like.
Cyber Sleep Walker
Cyber Sleep Walker
Thanks everyone for your suggestions both mechanical and culinary :), I will probably take it to a mechanic though as I'd have no idea where to start.
SQ_W211
W219 CLS55 AMG
Sorry to have stolen your thread but I gues houmor fixes many non mechanical issues
Sorry as well about all of the banter,,do check to see if the engine fan has been removed, I am just curious on this one
Cyber Sleep Walker
Cyber Sleep Walker
Is the engine fan the big one sitting behind the radiator ? or another ?
Sorry, I'm hopeless with all things mechanical.
We could be wrong on this and the car only having one rad fan,,,if there was a engine fan it would be mounted on the front of the engine on the water pump nose
Cyber Sleep Walker
Cyber Sleep Walker
I went to my mechanic today and he said that MBs are not really his forte :( which troubles me as in my experience it is difficult to find a trustworthy mechanic and I do trust that one.
He suggested changing the thermostat.
If that doesn't do it I reckon I'm going to have to find a MB specialist, don't suppose anyone can recommend one in Glasgow ?
Cyber Sleep Walker
Cyber Sleep Walker
Well, got a new thermostat and this seems to have not solved the problem but helped a little (doesn't heat up just as quickly) still hitting 100C though, also now the coolant light keeps coming on and off and on etc while driving now, checked the levels and they're fine.
Will this need to be reset ?
And if so do I need to get MB to do it or can an indie do that ?
There is nothing to re set on your car,,running at the 100º c is fine.
On most MBs the water level lamp switch is wired in series with the washer bottle lamp switch
Dec
Ireland.
W202
On the open road, the temperature should be around 83c, when you are stuck in traffic, the temperature will rise to around 100c and drop back to 83c when you get moving again.
Get whoever installed the thermostat to check the coolant level again, as there may still be some air locks in the system, the low level will cause the warning light to come on and off, perhaps as you corner.
Dec
Dec
It will be hotter that Dec,, the thermostat does not start to open till 87º c
