C207 2012 E350Cdi - iCarsoft DPF Data
MrGundam
C207 2012 E350Cdi
Hi Everyone,
I hooked up my iCarsoft V2 today to check the DPF soot % of my newly purchased MB and firstly I struggled to find any option which gave a % reading as I have seen in various YouTube videos etc. It did state the soot content in grams however (5.40g). Am I missing where to find the option or I assume all models give different live data and this is not one for mine?
The car is not showing a EML but I did find the following 'Historic' error codes but no indication of when exactly they showed up in it's past.
15FC00 - The learned values for component 'B28/8)DPF differential pressure sensor) are outside the permissible range
14CF00 - The positive control deviation during exhaust gas recirculation control is too high
14B700 - The control deviation of component 'Y27/9(Exhaust gas recirculation actuator) is too high
Below is live data readout of DPF. The last regen was at what I assume 94269 miles (mileage now is 102000 Miles / 164153KM). I had it on the motorway for 3 hours 2 days ago so was hoping a regen would have happened if needed then. I don't believe these iCarsoft V2 kits can force a regen.
Any pointers?
Thanks in advanced.
It is usual "fill level in %" but your reader only seems to show ash content and soot content.
Soot gets burned into ash during a regen, so this would seem to indicate that your DPF is not in need of a regen (the pressure differential indicates the same).
M
MrGundam
C207 2012 E350Cdi
That's reassuring to hear, thank you.
As far as the stored error codes. Given I don't have any EML should I just clear the codes and see if anything resurfaces. or is it best to be proactive and look into this more?
KennyN
Paisley
BMW 440i, Cayenne, ZX12r / ZRX11 / ZRX Monoshock
When i checked mine on the porker it gave the distance since last regen in meters , not km.
20201222_220413 by Kenny Niven, on Flickr
When i worked out the fuel usage / distance travelled post re-gen it tied in with the average display on the dash.
K
Tony Dyson
God's Country
2014 C 220 CDI W204 OM 651
Below is a print out of my 'Check DPF Filter' status just prior to a regen which triggers at 100% Fill, after you have chosen the details of your vehicle the choices to follow are from 'Manual'
Interesting to see the different screens of the MB V 2.00 and I've never seen any German text in mine but you will notice that I had only 3g of soot @99% full when the regen process was about to start.
BENZ_EN_TEST_00001>C(204)>Diesel>204.002 - C 220 CDI>Manual>ECM - Engine Control
Module(CDID2-CDID3 for Combustion Engine 'OM651'(N3-9))>View Data>Check diesel
particulate filter:
Total Frames: 218 , Supported Items: 14
Frame 1/218:
B60(Exhaust back pressure sensor) ----- 1.13bar
B19/9(Temperature sensor upstream of diesel particulate filter) ----- 146°C
Air mass ----- 595mg/Hub
B28/8 (Diesel particulate filter differential pressure sensor) ----- 0.01bar
B11/4 (Coolant temperature sensor) ----- 88°C
B19/11 Temperature sensor upstream of diesel particulate filter) ----- 163°C
Engine speed ----- 771rpm
Injection quantity ----- 5.90mg/Hub
Main odometer reading ----- 75186km
Fill level of diesel particulate filter ----- 99%
Soot content of diesel particulate filter ----- 3g
Ash content of diesel particulate filter ----- 0g
Total distance at last correction of ash content ----- 74540km
Y27/9(Exhaust gas recirculation actuator) ----- 50%
onefortheroad
uk.
Where did you go on icarsoft to get that data. My e350 shows me nothing in engine modules ,and the dpf obd2 menu says not supported??
Tony Dyson
God's Country
See the text above the dashed line in my post #5 above, it lists my choices to the location on the instrument.
particulate filter:
bc100
South Devon
S205 C250 BluTec Estate 2014
My iCarsoft CR V2.0 (1+4) does not show
Check diesel
particulate filter:
I can read other live data but DPF is not offered. Any ideas or do I need to open a dialogue with iCarsoft?
Tony Dyson
God's Country
Check diesel
particulate filter:
According to the blurb on the website it should, it advertises the same functions as my MB V2.0 model, have you updated your instrument from new, the current ver of software are herewith, there was a recent firmware upgrade for mine too ;
You should try contacting the retailer you bought from for support initially. I bought from https://ljmcardiagnostics.co.uk/ and find them a better resource than iCarsoft themselves!
bc100
South Devon
Will do. LJM asked me if I had updated the unit which of course I pointed out in the first email. Oh well we will wait and see.
bc100
South Devon
This is the reply I got from LJM this evening. Disappointing to say the least.
"what's the VIN?
our current scanners have NO DPF function in the list for any C class 205 cars yet,sorry .
NO FOR C(205) yet
for engine live data ,you can have a check "diagnostics " mode - Engine - see data stream ...
Or on OBDII/EOBD mode to read some data ."
I will follow up tomorrow if I find the time.
bc100
South Devon
This model has been out for six years.
onefortheroad
uk.
"what's the VIN?
NO FOR C(205) yet
I get nothing on either on my c207 .
bc100
South Devon
If I put W204 as the vehicle can I read any data at all? I'll have to try later today when my battery my charged.
www.W140.co.uk&www.r129.co
