Alex Crow
- Jul 9, 2009
- Location
- Super Suffolk
- W169, W124, w202, W203, KTM 250 EXC, VW T25 camper and a Polo in a pear tree
hello thus, i SUSPECT your front sam is u/s. it will cost you £250 and MUST be coded by a star machine. also it is very awkward to replace if you have never done one, and has about 8,000 wires underneath!! if you remove it you will probably not be able to check it/see anything wrong. so you spend £300 getting a new one fitted by a garage with a star machine, only to find out that your ecu has actually gone? yes, the wipers not working points to the sam, but they are wired through the scm or eis before the sam so it could be this module causing the wiper fault!
i hope you understand why i said the next step is to have it plugged in, i work on these cars all day, but when the star machine goes down i am often completely snookered! very little in the way of meaningful tests can be done with a multimeter when you have issues like yours. but while we are here...
your sam has two relays to power up the starter, firstly the 'P' (large yellow one?) relay powers up a circuit that feeds eg instrument cluster. this should be live with ignition on i believe, check for live at fuse 52 when ign on. this live is in turn switched by the 'S' relay (small black one?) when told to by the ecu. chek for output at fuse 51. the s+p relays are at the rear offside of the fusebox/sam unit next to each other.
***you could try swapping the relays with others on the board...***
