C220 CDI Loss of power
Justin0609
ROTHERHAM
C220CDI/2006/2200
I have a 2006 C220 CDI, 65k miles. I have stared to experience loss of power on a few occasions, there is no fault light but I have noticed a "whooshing" noise when I accelerate, as there is not enough air getting into the engine (Turbo) !!
Any ideas as to the fault & remedy.
justin
mersum1es
Finland
Exactly, check your turbo hoses... (black smoke also indicated insufficient amount of air).
oigle
2003 ML270 sold but not forgotten. 2022 Kia EV6 GT Line RWD
To explain further, you probably have a split hose or a poorly fitted hose clamp. This allows air measured by the MAF to escape. This results in excessive fuel injection for the amount of air actually entering the engine. Thus black smoke and a sensor telling the ecu that you have a problem - hence limp mode.
Check carefully for splits - they can be hard to spot.
Justin0609
ROTHERHAM
C220CDI/2006/2200
Thanks for the info, are the hoses easy to get to ?
