C220 CDi Turbo
D
darbeen
I recently purchased a C220 CDi yr. 2001 at auction.This week the turbo refuses to cut in so accelleration is crap. Is there an simple answer??
jberks
Turbos are in all the time, assuming there is no black smoke (blown turbo), possibly a stuck open wastegate? - not sure how it's controlled or actuated though - believe electronically.
piestore
manchester
cdi turbo
HI
there are many possible reasons for the turbo not to operate the main one is that the engine is in emergancy mode ( won't rev over 3150 revs in any gear) . Fault code would help
Its usually due to a VAC leak or somtimes a faulty vac transducer, leaking intercooler is also quite common and the one I am starting to see alot of is blocked exhaust, just drop the centre section of the exhaust and test drive
RJR28/12
lack of power
HI Piestore possible cause is vacuum transducer,check headlamp level control is working as this is vacuum operated if not possibly vacuum leak.Or could be air mass sensor without fault code its a guess...
RJR28/12
lack of power
D
darbeen
lack of power
Thanks folks
Lights do lift/lower so vac is ok but engine revs are limited to about 3000 rpm.
Wky and how do I resolve my problem
RJR28/12
Really need a fault code has the air filter been changed recently,could still be an air mass sensor.
joe bloggs
Couple of idea's, the intake manifold shut off valve may not be working, or the arm may be detached, can see underneath manifold (looking from underside)
Also there may be an air leak in the boost pipework or cooler somewhere, check all pipes are connected ok.
piestore
manchester
turbo
Hi Darbeen
have you tried anything yet ???
whats the fault code ???????
give us a chance
D
darbeen
lack of power
Took car to main dealer. Problem diagnosed as faulty Air mass sensor. New Sensor £86, Labour £173, all plus vat.
How would I have found the fault code?
www.ckinsurance.co.uk
