C270 won,t start first thing,changed injectors as recomended,changed rail seals as recomended,noticed now that after filter fuel pipe is free from air to low pressure pump,but after pump a lot of air in fuel line,do these pumps have a repair kit or should some amount of air enter fuel mix ?This is turning out to be a hair pulling and expensive repair on a car I love to drive.Please if you can help it would be great.The car wont start first thing but if you keep on turning over it eventually does then it,s fine all day,the new injectors seemed to cure this for about three weeks but now it,s started again.
