C280 V6 Starter Motor.
Status
Not open for further replies.
badboy5
I have been told that the starter motor on this model is difficult to get at being high up at the back of the engine up against the bulkhead.
Before I go crawling underneath is this so or is it in a more 'normal' position and relatively easy to get at?
The problem I have is that the motor engages and then on occasions dissengages almost immediately with a loud metallic ring. Some lubrication required an expert tells me?
Thanks for any help and words of wisdom.
1998 C280 Sport. Great car. 115,000 miles and just run in!
Myros
R107, S211, R170, C219
starter motor
All I know is it's well hidden on my straight six 280. I have seen other strings on this in the past. Have a go with the search function. I suspect you'll end up using copious amounts of MB grease on the starter ring. Get yourself some WD-40/plus-gas type releasing oil before you start the job and give any visible nuts/bolts/screws you know you'll have to remove a good soaking the night before.
Good luck
B
badboy5
Myros
Thanks for your help.
piestore
manchester
starter lube
Hi very simple prob
Special Lube avialable from MB to lubricate starter ring gear
sorted in 30 minutes
piestore
manchester
starter lube
Hi 500 sl
Your quote is incorrect as anyone can see from the previous post but the humour is recognised
Status
