C350 Cdi remap
Steve Paul Thompson
Liverpool
2010 W204 C350cdi Blue efficiency sport
  • #21
Just gave the car a run. The extra power and torque is very noticeable. Also Gaz, my revs go to 4,100 before gear changes.
Gazwould
C250 CDI
You technically should change up 3400 rpm absolute max .
How do get it to change up early , flappy ?
Merc torque converter slush boxes aren't the most coperative to inputs when at or near wide open throttle and, seem to have an agenda of their own .
Steve Paul Thompson
Liverpool
  • #23
Thanks Gaz, l,ll use the paddles if l feel the need to go faster.
allybassman
2012 C350 Estate
Looks good to me, here's mine for comparison (Wheel HP)
I shift up around 3.5k using the padles if i'm pushing on (gearbox sometimes thinks it knows better!) C350 CDI DYNO GRAPH.png
Gazwould
C250 CDI
Yep tell me about it , the gearbox ignores a flappy up change sometimes when pressing on .
Steve Paul Thompson
Liverpool
  • #26
I find that not accelerating on full throttle makes the car just as quick as its changing gear at lower r.p.m making the most of the low down torque.
Gazwould
C250 CDI
My findings too and why I added a strip of excercice mat foam to the pedal travel .
Gazwould
C250 CDI
10mm initially to prevent the double gear screaming wot kickdown on a low rpm torque monster , now drops just one :)
Then an extra 10mm to help the paddle shift upchange probability .
Steve Paul Thompson
Liverpool
  • #30
Thanks Gaz, l,ll look into doing that myself.
Gazwould
C250 CDI
Vertical strip similar to these horizontal ones.
Gazwould
C250 CDI
Enjoy your torque .
Steve Paul Thompson
Liverpool
  • #36
When using the paddles, do you think some kind of audible gear shift alarm set to the peak torque might be a good idea? A lot safer than concentrating on the rpm gauge. Steve.
Gazwould
C250 CDI
The ultimate solution for our TCU's would be
Sadly not available to us :(
Steve Paul Thompson
Liverpool
  • #38
Thanks Gaz, just did a search.Seems its mostly for Bmw,s.
Gazwould
C250 CDI
How amazing it would be to have all that comprehensive adjustment .
Steve Paul Thompson
Liverpool
  • #40
It looks like I,ll be getting a audible gear shift alarm then. Any recommendations?
www.ckinsurance.co.uk
