C63 S204 misfire / eml
rjhoy02
c63 amg w204
Hi, our 2010 c63 has developed a misfire on one bank. My obd reader has given me 5 fault codes. I've done an oil change (Mobil 1), swapped coil packs over bank to bank. When running the obd reader says its misfiring on 5,6,7 and 8. Anyone got any ideas?
Sent from my SM-A405FN using Tapatalk
P0019 and P0024 are your clue.
R
rjhoy02
c63 amg w204
I'll pull the sensors out and give them a look
As above, camshaft sensor fault.
I would also get cam timing checked. None of those codes say the sensor is faulty or has an implausible value, they all say the value is incorrect and specifically over advanced which would suggest the variable cam timing mechanism is faulty or the chain has jumped (though I would expect the timing to be retarded if it had jumped).
R
rjhoy02
c63 amg w204
I'll pull the solenoids out while I'm at it too
R
rjhoy02
c63 amg w204
Yes I would have e thought that too. Its ot been driven too hard and was running fine. The next morning it was running like a sack of sh*t. We had it serviced by a local independent merc specialist who used Petronas oil but don't know what spec., that's why I changed it again.
Uncle Benz
West Sussex
Mainly Mercedes
M156 won’t have jumped the chain. Cam adjusters can be troublesome, as can the actuator solenoids and the oil rings. With misfires all on one bank it may be worth checking for a blocked catalyst first though
That wouldn't explain the cam timing errors though?
Uncle Benz
West Sussex
Mainly Mercedes
You mean blocked cats? The cam adjusters and the solenoids can cause cam timing errors, certainly. There are three oil control rings on the phaser sleeves that go into, and seal the oil passages within, the solenoid units. They can break or wear, leading to cam timing errors.
I’ve seen these engines with timing errors stored but engines running well, so I wouldn’t immediately leap on the cam timing as being the problem. It isn’t a small job on these to even just check the cam timing. It’s quick and easy to check exhaust back pressure though - just the lambda to remove. It’d be my first port of call anyway
R
rjhoy02
c63 amg w204
Thanks Uncle, I'll pull the lambda probe out too. I did notice that there didn't seem to be as much back pressure at the left tailpipes but put it down to the lack of combustion on that bank
R
rjhoy02
c63 amg w204
Update: I have checked and reset the cam timing and hey Presto the engine is running sweet as a nut! No misfires or any faults showing now.
Excellent though it does beg the question of why did it go out of time?
SquabzZz
Essex
C63 W205
Nice one
Isn’t this a tricky job to do ???
R
rjhoy02
c63 amg w204
The only thing I can think of is Ithe wrong spec oil causing problems with the adjusters on the cams, combined with the battery issues.
R
rjhoy02
c63 amg w204
Nice one
Not really, just a bit awkward with the limited space available. Just a case of making sure the crank pulley is set to 40° atdc on #1.
The crank locking tool was a good investment.
R
rjhoy02
c63 amg w204
  • #17
I'll probably invest in some new oil control rings on the adjusters, the exhaust cam ones looked a bit worn
I can't think of any way that would do it.
Were both cams out or only one?
R
rjhoy02
c63 amg w204
  • #19
It's a mystery to me too. The exhaust cam seemed slightly out in relation to the inlet, but it's still running fine (touch wood)
