Camshaft Adjuster
dazwm
I have been told my camshaft adjuster has gone because a noise has been coming from the engine. A technician has unplugged the lead going to it so the noise is no longer there. He said that it will not cause any damage but I will lose a little power.
I forgot to ask him how much power and is it something that I need to get fixed straight away or can I leave it for a while?
star
Reading
Smart + others :)
Leave it connected, is the noise at about 2-3000 rpm, if so just the usual rattle from it.
D
dazwm
Yes the noise does seem to be in the early RPMs. So you are saying to leave connected and put up with the noise? What benefit do I get from having it connected?
star
Reading
Smart + others :)
Its ment to give you more torque from the engine.
Glenn Smith
Peterborough, UK.
I believe if it rattles it is faulty, i have a c230k and it has no rattle. You will lose a little power at the higher rpm without it, variable valve timing i effect gives two different stages of tune by altering the timing of the inlet camshaft. this allows you to have good power and driveability at low rpm along with good performance at higher rpm. Merc use this to give a good spread of power, honda use it to give screaming bhp at 9000rpm fro little engines while still retaining good low down power. I'd get it fixed
star
Reading
Smart + others :)
yes it is faulty/worn, but it will do no harm if left. i think the part is approx £300+vat + fitting. In an ideal world you would have no rattles but we live with some givin the cost of repair??
D
dazwm
The part is £400 inc Vat plus 4 hours labour at £120 ph +Vat. That is why I am in no hurry to get it fixed!!
star
Reading
Smart + others :)
Thats why I'd live with the rattle:)
kth286
E320 Coupe 95
dazwm
What car is it ? as 4 hours seems a lot.
Give car body + year, plus engine size + diesel or petrol etc etc.
star
Reading
Smart + others :)
At a guess, its a C class with a 111 engine fitted, gotta remove rocker cover, front upper chain cover, timing chain tensioner, and then replace adjuster bolted to cam and rebuild.
D
dazwm
You are close Star! It is a 111 engine but it is a CLK230 Kompressor W208 model.
chicows18
New Registration
San Francisco USA
C230
I have a 2000 C230 with I believe a 111 engine also. Makes that same noise. I have unplugged the camshaft adjuster magner connector and the noise goes away. Can I leave this unplugged?
Yes you can do that and forget all about it.:D
Dogfish
South of England
CL203 C220 CDI SE Sports Coupe. 2002.
Does this apply to a 611 engine in a C class W203?
