- Mar 25, 2010
- Location
- Tonbridge
- W221 S65 AMG - W204 C63 AMG + Various other MB's
- Moderator
- #21
Firstly, it's illegal to work of hfc and cfc refrigerants without certification.
Also, you need to evacuate the system and pull a vacuum before adding the correct amount of gas in (and oil) in.
You will up with a mix of refrigerant and air/moisture which will corrode and freeze thaw in the system, eventually causing it to stop working again.
Why not take it to halfords etc, ask them to remove the ac gas. Go home and change the sensor then back again for a gas.
