Can someone please help me to make sense out of a smoke test result?
Greg_0ry
R320
Mercedes R-Class 320
2009
Size (cc): 2987
My car dis pass what is great but I am not sure how good ir bad the values I am seeing are so a bit help would be very helpful.
Uncle Benz
West Sussex
Mainly Mercedes
If you look at the vin plate in the drivers door shut there is a number in a box which is the test limit for your car. 0.51 in this case.
Uncle Benz
West Sussex
Mainly Mercedes
If you have no moral compass you can scratch that box out and they have to test it to a higher limit based on the vehicle age.
curious
Only the Vito left! W639/1 OM646
The maximum smoke value for your 2009 R320 will be either the plate number, as described by Uncle Benz, or 1.5m-1 if no value in the box.
G
Greg_0ry
R320
It seems it’s 0.7
However, it doesn’t tell me if the values I see from the test are higher than they should but still under limit or if they are normal
curious
Your test value would be 0.7 and fortunately 0.43 is under that.
Do you know what the historical values are to see if it's moved much over time?
G
Greg_0ry
R320
I am able to download the test certificate I believe so let me find out (Good idea btw.)
curious
I don't think it's on the test certificates. It's usually given to you at the time the test is done on a separate piece of paper printed from the smoke test machine (as in your initial posting picture).
G
Greg_0ry
R320
I actually found most of the results in one of my folders and it seems its sometimes high other times low. I have the strong feeling it depends on how hard they test but anyway I am ok with that for the moment.
Thanks everyone for your help
M80
Derbyshire
or how hard it's been driven before testing.
Up to temp, a good hoofing, can clean them out.
As can some additive, but some are snake oil.
G
Greg_0ry
R320
Yes, you are correct!
My car has failed last year and tge tester suggested to take the car for a spin before testing and it has worked :)
M80
Derbyshire
Tbh the smoke test is a patronising attempt to show the population that there is attempt to reduce emissions.
Testing at different state of engine temperature, usage can create different results.
It fails cos the engine isn't hot enough.
It fails, gets hoofed, and the retest is satisfactory.
It fails, someone pours in an overdose of additives, retest some time later, and hey ho.
Some poor sucker might scrap the car because of a tank of poor fuel.
I'm not saying it's common but some great results are due to the tester not inserting the probe so far.
In essence wot am sayin' bro is a test dont not mean the car is gud or bad. More lucky or unlucky, imvho.
G
Greg_0ry
R320
Thats a little bit my thoughts to be honest.
www.ckinsurance.co.uk
