Can you trust a trolley jack. ?
dieselman
A diesel
I assume you don't still have this jack, if so take the seals to a local seal supplier, they will match them.
That was approx 1973, and no it went as scrap :(:( No internet then
Dosco
W211
NEVER trust hydraulics - 1959 as a craft apprentice I was on the afternoon shift carrying out maintenance on a power loader and was sent off the face to make up a new 1.5 inch diameter return hose for the cutter head lifting rams. Whilst I was off the face the craftsman crawled under the cutter jib, all 7 tons of it, and started to remove the cover plates when the leaking hose burst releasing the h/oil from the rams allowing the 7 ton cutter head to drop down - he was never to see his family again.
When working under a car it is also wise to chock the wheels even when on axle stands - takes no time at all.
Very true,,I have my car on stands right now, I point the odd foot towards the front as they can tip with the P brake off and in N unless the ground is dead level, just the effect of undoing a wheel nut on the opposite side could roll the car off
47p2
Scotland
W638, W140, W220, W639 All gone but not forgotten
Well I was going to paint it and make it look nice ;):D
I've often thought I should give my old trolley jack a paint, but I'm sure if I did it would start leaking :lol:
Just wash it down and spray the thing with any old left over paint
47p2
Scotland
I couldn't do that Malcolm, I would need to have the paint matched up to the original colour and a full restoration done ;)
HERBIEMERCMAN
HERBIEMERCMAN
PRESTON, LANCS.
97. E300.TD. 7 SEAT.ELEGANCE. EST.TOYOTA SUPRA MK4. RS. VAUX. CORSA.GLS AUTO. SPORT.
  • #73
we don't need to go into the "benz bin", we can mix it with engineering, sort of lightening up the subject, it's a bit like the bbc news, they just showed 20,000 dying in the floods in pakistan, then the next item was a man who had the worlds largest collection of chrisp packets!. if stargazer is like her picture then we need to have more member's meetings. herbiemercman.
kebo57
Lanc's
ml270
i have just had two 1.5 ton trolley jacks supporting the front of my car, one under each side whilst i am changing the autobox oil cooler pipes on my e-300 est. car..
both jacks are the diy types, i think "nu-tool" is one of them, it is 2 yrs old and working fine. the other is a similar make and i have had it 20 yrs, this one today started to slowly lower itself, with oil seeping passed the oil seal on the pump shaft. gave me quite a scare.!
because i was using two jacks i felt safe, but i am now questioning this? and i am buying two axle stands tomorrow.
i have seen many mechanics relying on just the one jack and a local mechanic was crushed to death some years back here in bamber bridge, pear tree garage, where a 10 ton tower jack hydraulics failed and he was stuck under a coach. familarity breeds contempt. i am posting this as many out there may have got complacent as i had. herbiemercman.
Hi could be an easy fix for that jack
(started to slowly lower itself, with oil seeping passed the oil seal on the pump shaft)
Probably a ball bearing in one of bores/holes in the jack housing that isn't seating properly you need to make that seating better maybe tapping the ball with a flat end punch
Kevin
stargazer
manchester
c180 esprite
Im good enough! but im afraid my car isn't good enough !!:(
This is my trolley jack, it cost me £3 some ten years ago, the nice thing about it is it is so low and will go under any car with ease
Dosco
W211
Do I see some rust young sir:shock: warranty claim pending I'll be bound;)
