I suspect that the window switches are located by the transmission stick. I can't help with that.
But the centre upper console for GrahamH can be removed as follows:
pull off the rotary heater control knobs (fan blower and directional air flow), undo the nuts behind these knobs i.e. where they were before you took them off, and lift the wooden piece out - lift at the lower edge to do so. The bulbs are in front of you. Be sure to fit the correct voltage bulbs as too high a voltage will heat the switch too much.Hope that's helpful.
The knobs come off fairly easy. Cover them with a piece of cloth/towel before gripping them with the pliers then just pull. The retaining nuts are behind them. See previous posts about correct wattage of bulbs (I think they are 0.3 watt).
Just a thought but on the W124 there are two screws holding the bottom of the console. Might be an idea to look at the bottom edge before starting on it.
Stop looking for the Best Garage!! We are here
and have the best advanced solutions for you,
at Competitive prices.
Put us to test with any issue you may have.
