shayes
- Oct 10, 2002
- as stated
Have you taken off the various under panels?
From memory (and I've not done the job you are wanting to do) you have to take away the side panel next to the accelerator pedal, then you can remove the three screw panel above your knees which links to the centre air vent, and it exposes the area above.
Then you need be on your back in a less than ladylike position on the reclined seat looking upward.
but..maybe wait for someone more experienced in case there is an alternative means of access.
