Changing ignition tumbler
shayes
as stated
Have you taken off the various under panels?
From memory (and I've not done the job you are wanting to do) you have to take away the side panel next to the accelerator pedal, then you can remove the three screw panel above your knees which links to the centre air vent, and it exposes the area above.
Then you need be on your back in a less than ladylike position on the reclined seat looking upward.
but..maybe wait for someone more experienced in case there is an alternative means of access.
You may have to remove the cowl as well as the under dash kick panel, I will take a look this evening
Just checked and I have the main page already printed off, I can send it to you
100%Bitch
100%Bitch
Norfolk 'n' good
215 CL600, 216 Facelift CL500, 172 SLK55, Nissan Cube, R170 SLK230 & an Auto Trail Comanche.
  • #64
EEEEEEEEEEEEEEEEEEEEEEmail please :D:D:D
You should have it and you can edit out your address :D
If you need more then I will find with luck some links
100%Bitch
100%Bitch
Norfolk 'n' good
  • #68
Thanks for that Malcolm, but just to be a pain in the rear, I still don't know how to remove the dashboard fascia to get to the steering lock. It's impossible from below to get to anything.
100%Bitch
100%Bitch
Norfolk 'n' good
  • #70
Thanks Malcolm, I'll give those instructions to my pet garage man so he can do it. I don't have the patience. :lol:
100%Bitch
100%Bitch
Norfolk 'n' good
  • #71
Well Malcolm, your magic worked.
I read through those instructions and although it didn't go quite to plan, I now have a car that is in perfect working order.
Thank you very much for finding that for me.
shayes
as stated
Excellent news - bet the original key turns up within twentyfour hours !!
As long as Helen is happy, we can have a happy forum :D:D
