Charge a Dead battery help
hod05
E 250 cabriolet, 190E 2.0L
Hello
I have an E class 250 CDI that I've had sitting idle since the lockdown began and now I'd like to get back on the road.
Unfortunately the battery has gone dead. Still power to the radio and dials just not enough to start the engine.
I have a charger device but I'm unsure I can use it. If it is suitable (see pic) I'm concerned about doing this incorrectly and damaging the electrical system.
Reading the merc instructions book it says a jump start can be done by connecting the positive terminals of both batteries together and the negative to the earth point in the engine bay.
3 questions
1. Is this the same case if using a charging device? Positive to positive negative to earth?
2. Where is the earth point? The manual diagram isn't very good they could have done to provide a better drawing.
3.is the pictured charging device suitable? Do you need to buy a specific merc one or some kind of merc approved one?
Thanks. Sorry if it'd a daft question but I've heard some horror stories about jumping these incorrectly.
Cheers
Edit
Is this the earth point with the brown wires?
Tony Dyson
God's Country
2014 C 220 CDI W204 OM 651
In answer to your questions;
1, Yes
2, Earth point 5 in your manual is a brass coloured pillar mounted to inner wing adjacent to your FOS shock absorber
3, Your battery charger is a basic charger and fit for purpose, turn everything off in your car, connect the charger and turn it on, the indicators should indicate when charging is complete.
hod05
hod05
1, Yes
OK thanks a couple more questions, do I need the key in the ignition or not. If the key is not in the vehicle everything will be switched off?
Is this the earth point? I can't find anything brass inside the engine bay
Thanks again.
Tony Dyson
God's Country
No key needed
Yes, + to 2 under red slider 1 and the earth point should be as indicated at position 5
Any sound metallic connection to the chassis will do and if you can purchase a good connection to the brown wires lugs this will be enough to carry the charging currents.
hod05
hod05
No key needed
OK thanks alot couldn't quite get purchase on the brown lugs but got a good connection on the bolt that secures them so hopefully it'll be OK
grahamcol
West Midlands
2001 SLK230, 2007 CLK220 CDI
Just a word of caution. Not only is the ignition key not needed, it’s a positive no no to have the key in the ignition whilst charging.
Donald McPherson
c180 komp elegance se a 2005
Just about every car built in the last 10 plus years will have something still on even with the key off and removed.
Personally I prefer to remove the terminals when charging.
EmilysDad
Bury Lancs
ML350
but not every car has an easily accessible battery .... mine is under my seat & not that easy to get to, but there are nice easily accessible charging/jump start points under the bonnet :)
range rover
Northern Ireland
E Class Blue EFFICIENCY 250 CDI Sport 2013
Couldn't agree more, that way you are sure nothing is going to get fried.
Submariner1
Windsor Berkshire
CL500 2009 5.5
I was told to switch off all consumables, such as auto lights, air con, Comand, and remove Keyless Go plug. and not to use negative on Battery, but use the Earth Stub! To ensure I did not circumvent the Battery Control Module!
