CL63 AMG crash and repair
Cipollini
Slovakia
w216 CL63 AMG 2008 w211 E270 CDI 2003
Hey guys,
yesterday I had a crash with a deer. Will post some pics later. Deer was unlucky and immediately dead, but the car turned out well considering the car speed and deer weight.
I´ll need new (or used) hood, bumper, left fender and left headlamp. And some small parts of course.
I found CL500 with AMG body for parts sale, will those parts match my CL63?
Naraic
2005 CL500.
Probably. What year is your car?
C
Cipollini
Slovakia
Yes, 2008
mioba
Nottingham and Köln
Glad you are ok firstly.
Whats the score with insurance over there.
C
Cipollini
Slovakia
Thanks, yes I was lucky, it could have turned out much worse than this. I´ve seen many crashes where wild animal ended up inside the vehicle.
What exactly do you mean? In this case my insurance doesn´t cover collision with animals. Now I regret I didn´t pay for it the extra cash.
Anyway if the CL500 body parts are the same as CL63 it won´t be so expensive repair. Mechanic said the front plastic bumper is repairable, the toughest job will be to find xenon headlamp with ILS.
mioba
Nottingham and Köln
You answered the insurance part.
I can imagine the headlight being expensive. p
C
Cipollini
Slovakia
The fender should be the same as mine, so I´ll buy it, but what about headlamp? I have one with Intelligent Light System, are they all the same? My broken headlight number is A216 820 75 61 and the second hand one from CL500 I´d like to buy is marked A216 820 23 59.
Can anyone confirm they are the same? I asked MB dealer, but they cannot confirm which one is ILS or not, or if they are compatible.
Thanks a lot
mioba
Nottingham and Köln
To be on the safe side I would be looking for the same pn as existing
C
Cipollini
Slovakia
I am glad I even found some headlight for sale, these are pretty rare.
As far as I understand, there are many serial numbers through production
C
Cipollini
Slovakia
unfortunately I crashed my CL63 and need new front left headlight. My broken headlight number is A2168207561 and the second hand one from CL500 I´d like to buy is marked A2168202359.
Even MB dealer cannot confirm they are the same (I need ILS headlamp).
Can anyone confirm they are interchangeable or not?
Thanks a lot
mioba
Nottingham and Köln
I thought you said on the other post you sourced the right one.... so a bit confused.
As mentioned get the same pn headlight.
look on the likes of partsourq to confirm the pn based on vin
Misterdog
A160 (W169) 2010
The wheel size on my Merc is incorrect on the OASIS print off that my local dealer provided me with.
Part numbers can change as Mercedes change suppliers or specifications.
Mercedes does not manufacture headlights, bulbs, batteries, spark plugs or brake pads, they are bought in from other manufacturers.
I once had a VW Passat which had Bosch headlights, these were also fitted to a Ford and a BMW.
Cheapest from Ford, then VW them BMW.
Same part :)
Different numbers from each marque.
C
Cipollini
Slovakia
I sourced the right one, but I am not sure if it has ILS. Even MB dealer cannot confirm that
C
Cipollini
Slovakia
Same part :)
That´s basically what MB dealer told me. There are plenty of headlamp versions (including colour differences) and therefore many serial numbers. Whatsmore they were changing those numbers during production
peterws1957
Lancashire
Might be worth looking at the website 7 zap Mercedes Chassis Europa and trawling through the options for the headlamps. The site does seem to update part numbers but lists the old ones.
C
Cipollini
Slovakia
  • #17
I found result only for my headlamp
Anyway I decided I´ll buy it even it´s not ILS so the car can be repaired soon.
If it won´t be ILS, I´ll keep searching for the right one and replace it later.
C
Cipollini
Slovakia
  • #18
Reply from official dealer:
,,The vehicle is equipped with the codes (M156 + M63 / M275 + M60) + (614/615/622) + 610 + ET:
A2168207561 => A2168206361_left side
A2168207661 => A2168206461_right side
A2168202359 => A2168202759> codes (614/615/622) + 809. These lights are not for AMG or vehicles with code 610 (the AMG vehicle is equipped with this code´´
Does anyone know for which vehicle is the A2168202359 lamp and if it will work or not?
I think the software and conector must be the same.
PM me your vin and I will post the headlights PN's suitable for your car.
Night vision is a different headlamp, they have a IR bulb where the high beam halogen would usually be.
