CLC speaker cover.
Andy.M
Rochester Kent
2014 GLA250 Premium Plus, Night, AMG Exclusive Leather, Driving Assistance Packs COMAND DAB HK Audio
Not arrived here yet Malcom.
Please check your junk box,,, I have sent it again 5 mins ago
Andy.M
Rochester Kent
Thar she blows!!
Came straight through that time - thanks
Philb280
Preston
2009 CLC 180
Hi
My Mrs has just bought a CLC and unfortunately damaged the speaker cover on the drivers door - please could you forward the instructions to remove the panel for fixing - its a 2009 CLC 180
Thanks in advance
Phil
Details sent and you can edit out your address
when you fit the new cover just melt over the lugs with a soldering iron tip
I have sent it to you, you can edit out your address
Pilotpenguin
Crawley
CLC 180 Coupe Sport 2008
Speaker Grill Mercedes CLC180
Hi guys
I've got a Mercedes CLC Coupe Sport 180, however the front right drivers speaker cover has cracked. I've bought the new speaker cover part for the door, however I don't know how to fit it.
I am under the impression the door panel needs to come off, Mercedes quoted me £180 to do this! So I'm after some instructions from someone on here who knows how to do it...
Anyone have any idea? I could do with a step by step guide. I'm also aware the door may have an air bag in it so I need some good instructions.
It seems very unnecessarily complicated!
Kind regards
Steve
bruno2009
Nottingham
W203 CLC 220 Sport
I have had mine done under warranty and was told it takes an hour to fit!
When you have taken the door card off and everything else you will need a soldering iron to melt the plastic lugs on the speaker cover itself.
The reason the covers break is that if the seat belt has not retracted fully and you close the door it actually traps the buckle between the door and speaker which then breaks.
bruno2009
Nottingham
W203 CLC 220 Sport
Hi guys
Kind regards
Steve
If you pm television I am sure he will send you the instructions on how to replace the cover.
Hi guys
Kind regards
Steve
Pop your Email address up and you can edit it out when I say shortly
I sent it once so probably in your junk box as it has not bounced back, but I have sent it again
stormtrooper
Manningtree Essex uk
54reg C180k coupe 1800cc/02 112cdi Vito duelliner
SPEAKER COVER
Hi television
I've done the same thing and put the metal seatbelt through the speaker of my C180K Coupe 54 model.
Please can you send me instructions in how to remove the door panel in order to replace the speaker cover.
My email address is jackienunn@hotmail.com
Thanks is advance.
whitenemesis
CLS55 AMG '05
Malcolm won't be around for a while, you may want to edit out your email addy?
hammerskin
New Registration
Salisbury
CLC220 2009 2.2 diesel
Hi Television, could you send me the fitting instructions, just holed the speaker cover on my wifes, have the part just want to try and avoid breaking any clips taking the door card off. hope you can help.
Hammerskin
Hammerskin
Email address please you can edit it out later
www.ckinsurance.co.uk
