Cleared my Check Engine Light...
starship1701a
Vancouver BC Canada
1998 ML320
2 codes came up on my ML320,
P0301 Cylinder 1 misfire detected
P0400 exhaust gas re-circulation flow
need a little help please... so if im going on the highway up a hill and then stomp on it, under load the car would start misfiring... later after restarting the car its all good.
#1 cylinder is passenger side front?
should i change up my coil pack for #1? spark plug?
should i change out the EGR ?
Botus
S500/2010/500
not sure if this is correct
It's contradictory....
No1 drivers side front of car. The front cylinder other bank is no 4.
Swap coilpack 1 with 4 and see if the fault follows the coilpack.
It's rare an EGR causes issues on a petrol engine.
