clk 230 will not rev above 3500 rpm
gsk
Hi,members,
I hope that you can help,i have a 1999 v reg clk 230,which will not rev above 3500 rpm with an intermittant misfire at number four cylinder i have fitted a camshaft sensor but it did not cure the fault it also feels like the exhaust is blocked causing flat spot/loss of power,
Thank you for any advice gsk
G
gsk
clk 230
It will not rev in neutral or in drive,
Thanks.
Mr Teddy Bear
Bristol Between Mill & Cutting
1998 W208 CLK 230K SPORT: MG F 1.8VVC: Flame Red Rover 216GTi
Any strange noises, what's the consumption like??
how long have you owned the car..
just a thought...supercharger bearings, is it a kompressor?:confused:
idz92
merc SL350 06 3.7ltr
clk 230
I had same faults put new coils plugs and fuel filter[£340] didnt work then cleaned throttle housing and air mass meter erase fault codes change fuel to higher octane [as manual] £29 It worked for me
G
gsk
clk 230
Hi,i have dropped the exhaust centre and rear exhaust sections and the front exhaust boxes are burning red inside,it feels as if the exhaust is blocked,with a massive flat spot misfire at 3500 rpm,fuel consumption is terrible,it is a kompressor,
Thanks for your replies.
The cats being blocked is a common fault on this engine sad to say
