CLK Electrics Mystery
Speednut
Sheffield
2001 CLK 230 AVANTGARDE
Driving home today doing about 45mph when suddenly dashboard lights and everything went dead for about a split second, just like when you turn ignition off but there was no loss of power. This happened twice with about 5 minutes interval between, but has not done it since.:confused:
Advice please car is 2002 CLK 230 Kompressor
Regards Steve
Cole@MBS
www.mbssouthampton.co.uk
Common for the 208 cluster to go down, could be the start of the end!!
Speednut
Sheffield
Sounds expensive, it was just as though you had removed ignition key, lights off all needles returning to start positions etc. then just as they had gone off everything sprang back into life.
wardpaa
Deepest Suffolk
CLK 270 CDI
Might as well check the fuse is seated correctly in position 42 ? On mine its the fusebox in the cockpit drivers side.
Would be lucky though.
Speednut
Sheffield
Cheers mate will do
Steve
Speednut
Sheffield
Can anyone tell me what a new cluster would cost, assume this is the complete instument binacle
Cheers Regards Steve
A
andy@pcd-ltd
Without the chassis number can only give you a rough price but they range from about £400 all the way up to £800 ouch
As this could be the EIS switch doing this,,the car should go on to STAR to prove this point
Speednut
Sheffield
Cheers Malcom
As the service indicates only 2400 miles to an A service I will wait till then and let Merc dealer in Sheffield have a look
Steve
